Cub Sickle Mower End Knife
Hotflashjr
Location
Western MA
My cub sickle bar mower has a double knife on the end. I used to have a #5 JD sickle bar mower with the same. I think they make a big difference. The cub double knife seems to be a smaller size than the double knife I had left over from my #5 JD. Is this a standard size knife on the end or do I have something different?
Does anyone have a source for these?
(quoted from post at 07:41:28 08/31/20) My cub sickle bar mower has a double knife on the end. I used to have a #5 JD sickle bar mower with the same. I think they make a big difference. The cub double knife seems to be a smaller size than the double knife I had left over from my #5 JD. Is this a standard size knife on the end or do I have something different?
You are looking for a section for a knife. The individual "knives" are called sections, All the sections on the knife back make up a knife. There are different sizes and types of sections. You should be able to find the correct section for yours a number of places. Many on line places sell them. I don't know what the number yours needs is, but a search for Cub sickle bar mower sections should get you some options. If you have the model number of your mower that may help.
I think the "double knife" configuration
you are talking about is an "after
market" development. Probably done by
Hershel or some other aftermarket
supplier of mower parts. You'll have to
find one with the correct rivet hole
spacing-I doubt if you're going to find a
part #.
Thanks Old. I will see if I can get my hands on one of those. The one I have from my JD No.5 the holes do not line up and the last tooth is actually larger, not by much, but it doesn't seem like it would work correctly.
