cub with governor issue
brooksie
My cub runs at a high RPM only as I cannot adjust the carb/governor shafts. I can lower the RPM temporarily at the the carb but the governor then revs the motor back up. Is it possible something is frozen in the governor? The governor shaft in the front of the tractor does not move when I adjust the throttle shaft.
Thanks for any help.
You need to take the governor off and repair it. It could be simply stuck or have a bad thrust bearing or broken weights, amongst other things.
Be SURE you understand timing it ('cause it drives the mag) BEFORE you remove it.
There's LOTS of manuals on-line ay RudisFarmallCubs.
Here's the URL...
http://www.cleancomputes.com/Cub/index.html
