Cultivator, solid shank vs spring shank
Maineman
I have a Dearborn spring shank cultivator. I just love it! Flicks stones right out of my field! But, I wonder where does a solid shank cultivator come into play? What is it best used for?
Joe
A solid shank works well if you have no rocks...When
I leased a field up in the "rocks" I had to get a
spring cultivator.And a spring trip plow(after I
destroyed my old rigid beam....)
I just the other day caught a root with my spring shank cultivator and broke a shank.
friend welded it back together, but I have little hope it will hold.
I understand welding spring steel draws all the carbon to the welding area and it becomes brittle. so it will break again around the welded area.
so I have found a supplier that sells replacement shanks if and when it breaks again.
however, I would think the spring shank will take more abuse. will shake in rough hard ground and may loosen the soil better.
I have used both type cultivators, the old AC front cultivator had straight, but had spring loaded kickbacks to protect itself.
(quoted from post at 18:54:54 06/29/13) A solid shank works well if you have no rocks...When
Soil with no rocks? I'm more likely to have rocks with no soil!
Thanks for the info!
Joe
My experience has been if I need to run furrowers or hillers, or very wide sweeps, the solid shank holds them straight at a constant depth, while the spring shank bounces around too much and "porpoises" up and down. If I need to run narrow sweeps or points, the spring shank bouncing around does a better job of loosening than the solid shank.
