ittle holes in the top that go through to the top ring land. The pressure created when the piston goes up with the valves closed pushes the ring out for a better seal. I had heard a long time ago that a lot of diesel engines have this. It's something that's common in racing engines. Allows the builder to use low tension rings.(quoted from post at 22:27:07 12/10/20) Gas ports ?
