curved beam 3pt subsoiler
Jim Eubanks
I have an older curved beam 3pt subsoiler that needs a new point. Cannot ident. mfg. Beam with 3pt pins has dip to accomodate a coulter. Point is 8" tip to 1/2" single mounting bolt and would be reversable which would make it 16" overall. Can anyone help with brand ident? Source for pt?
I have a Harry Ferguson subsoiler with a coulter that sounds similar to what you have. I can't locate a point for mine. I am taking a 2-bolt point from a newer subsoiler and am going to weld 'ears' on the back of it so it won't rotate on the single bolt.
Here's a point that fits a JD curved beam subsoler. It's not reversible and it's held on with 1/2" bolts.
Part Number: A17994
Part Price: 31.99 USD
Description: POINT
Thats it, Ferguson D-Be-28 Sub Soiler, maybe someone on the forum will know where we can get a point for this subsoiler.
That part comes up as a chisel plow point. Different machine. The Ferguson subsoiler has a curved beam but the point is straight, with only one mounting hole . . . it is kept from rotating by being cast with a channel down the middle for the beam to fit into. It apparently has been an obsolete part in the Massey-Ferguson system since well before AGCO.
