custom planting charges
dairyman
What is a fair price per acre to charge someone to custom plant some corn this spring? I was thinking of charging for the use of my equipment and time on a per acre basis and charging for the materials individually. But I do not know what to charge per acre for my time and equipment, the materials will be charged the same as it costs me. Thanks for your help.
Hourly rate will be your best...and I would have to be paid ahead on seed, fert. etc...based on store receipts, etc. Hourly rate also needs to cover your time to fetch seed, etc...not just time you are on your tractor, etc.
How much to charge....size tractor, other equip. etc....more info might be helpful.
When I did landscaping work, there was always the "while you're here would you do..." and I personally gave up on contract work. I would give a "quote" but not a contract price....never had much problem and mostly came in under "quote" by a few dollars.
My $.02 worth
I have charged $25/acre to prepare and plant, with one pass cultivation before planting, but would make too passes if necessary. This would not include plowing which would be an additional charge. He pays for the imputs which are usually seed, fertilizer and chemicals. He also pays for all custom applications of fertilizer/chemicals, but includes fertilizer with planting if desired. Travel wouldn't be a consideration if he was within 5 or 6 miles, unless it was just a small patch, such as less than 10 acres. Also charged $25/acre for harvest which included hauling 5 miles to elevator.
A formula that has always worked for me for equipment cost to my own operation is fuel cost plus 50% of fuel cost per hour = what I need to perform maintenance and fix the common breakdowns. For custom work, I would double the above figure and add in the hourly wage I wanted to be paid. If anybody balks they have never owned and maintained equipment.
