Custom wiring harness
Is there a vendor that will make a custom wiring harness for my 1947 Farmall A, based on my specifications i.e. Delco alternator, governor, front and rear lights, etc. ??
Yes if you want to spend 150 or so and the gov doesent need wiring. It would be easier if your A still had the gen and reg to find one. Got to be careful ive seen some that are too short and cannot be routed the original way. The harness for the rear lite is a separate wire and sold by itself. You will need to have the diode located in the control box if you want it to look original but going to a ALT it will not be original anyhow. Steiners, Brilliams and others coult make one. You could use a stock harness thenchange the Batt end terminal to fit the ALT.
I always make my own. Not much to wiring a tractor with an alternator and simple lights and the cost of me doing it is well under $30 unless you include buying the lights. When I built my BA which is half B and half A I had to do a complete wiring on it
