(quoted from post at 19:47:29 09/18/17) 1/8 wall sq. tubing and .063 sheet
i:5c5cf91a5c](quoted from post at 12:28:20 09/19/17) If you are going to cut very much it might be a good idea to get a metal cutting bandsaw. [b:5c5cf91a5c]Cutting anything round with a miter saw or skil saw can be very dangerous. While it will work if you take too much and it grabs it will spin the tubing. The sheet metal can be cut alright with the skil saw and would be better to use an aluminum cutting blade. Not the carborundom blades but a fine tooth blade made for aluminum. [/b:5c5cf91a5c]https://www.mutualscrew.com/product/ivy-classic-aluminum-plastic-circular-saw-blade-swift-cut-143537.cfm?source=froogle&gclid=EAIaIQobChMIr6D6uvqx1gIVDYhpCh09cg4mEAQYAiABEgIKLfD_BwE
