cylender compressin
Bruce Alt
I have a 1947 international M. I have not found out
what the cylinder compression should be. I am getting about 95 pounds per cylinder. Would like to know if this is enough if not what should it be and is it time to overhall it.
Thank you for your time.
Bruce
if there all around the 95psi it sounds ok for it. is it using oil. other signs to look for also. plugs burning clean? what are you doin with it? idling around not getting to operating temp. no good. work it hard- good.
Hi Bruce: Gotta remember that there could be a low compression distilate head on it and/or low compression pistons rather then 5000ft pistons etc... so all cylinders similar is "good" and better is using not much oil and clean plugs showing no or low oil usage... after compression test, pump 2 table spoons of clean thiner oil into each cylinder wall and wait an hour for oil to run all the way around piston top down unto rings... do another compression test. If about same your engine (pistons & rings are good) so just use it & enjoy it... good luck.. If you want more power, look for a rebuilt super M with high compression pistons. Lots of money can always buy more power but the rest of the drive train needs to be better also... good luck.. ag
