Cylinder head machine marks
Fixingfarmer
Had been waiting 4 months for 3 cylinder heads and a block to get done locally so I tried getting one of my personal ones (jd 38B lawnmower the spare cylinder head aka the original) resurfaced as a test of a new place. It came back completely smooth no cutter marks like an aluminum car head. I have never seen that on a cast steel head heavy equipment head. Thoughts as to is this a personal preference or should I mention it to the new place or continue on to somewhere else he had a 466 head sitting there which is similar to the next project and was done in a week. I understand the importance of keeping the relationship with the place I have been currently going and have used them as much as I can but I also at that rate would have to have 9 things in the shop at once just to keep in the black and that's not feasible (nor should it be).
Regardless on the B it will be tried as it is but it will be awhile.
Thoughts appreciated!
MANY years ago a machine shop I was using replaced their wet cylinder head GRINDER with a Van Norman Rotary Broach.
They did work for area John Deere dealers including warranty work and DEERE didn't want the head surface shiny/mirror smooth, but rather wanted a specific "roughness" to grip the gasket.
Thats a little bit what I was afraid of. How do I describe that to the machinist? Im leaning toward saying I want to see the machine marks when done as they are when the head arrives...obviously he tried to do a really good job on the B I told him I'd have a lot more for him...and for cars and such I think he's spot on.
Surface finish on sealing surfaces is dependent on the gasket material used and the materials being sealed. As noted above, there is a spec for many applications.
I would ask the machinist it should be an easy question for him to answer. Personally I take my work to a shop that's well equipped to offer the best possible outcome for the application. Those that did not keep up with changing technology are out of businesses AKA your local auto-parts machine shop. I have been bit bad from some work they did because they used one set up are machine for all applications. The info you are asking is out there.
