Hi Guys
A couple of years ago I bought a semi basket case side mount 8n. Ive been getting it back together and finally tried to start it (I did put MMO in a while back). It spun like it had no spark plugs in. I took the valve covers off and all the valves were working except one. I then checked the timing mark on the flywheel and it was ok. I pulled the head today and found that a PO had taken the head off and put it back on with no gasket. The cylinder walls feel very smooth except for some surface rust. My plan is to put a new gasket on, see what happens, and go from there. My questions are:
1. Should I use some 0000 steel wool the try to clean the surface rust off the cylinder wall?
2. Can I or should I use a small wire brush to clean around the valve seats?
3. Would a steel brush on a drill be too rough to clean up the bottom of the cylinder head?
I consider myself fairly intellegent but I cannot figure out how to upload some photos I took.
Thanks for any suggestions and/or help!!
