Cylinder Sleeve Puller
RockinB
I"m in the process of replacing sleeves in a 1550 gas. Not having any luck borrowing one, and the price of a new one is darn near twice the price of the sleeve kit. I"m considering improvising one, and wonder if any of you have done the same,while working under the shade of a tree as I am. Any and all ideas would be appreciated.
I made one. I took a piece of half inch plate cut to the right diameter. I cut a flat spot on both sides so it would slide down in the sleeve. I've got that welded to the swivel part of an old 1 inch breaker bar. That's welded to a piece of a U-bolt from a truck spring.It's a fine thread. On top,I used another half inch plate welded to two pieces of channel iron. With that swivel on there I can drop it down from the top and work alone. With those wet sleeves,you don't have to raise them very far for them to pop loose.
Thanks; The plates and threaded rod is what I had in mind. Your idea of the flat spots and swivel bring it up to professional grade. What difference would fine thread as opposed to coarse have; just a more gradual pull? Thanks again.
I've decided to incorporate your flex handle and two flat spot idea into my home built puller as the combination of both is a great idea. Ihave found a sacrificial 3/4" flex handle which I think will suffice, some 3/4' coarse thread Allthread, and a piece of 5" C chanel with 1&1/2" legs for the top plate. The 1/2" bottom plate I'll have to have made up. The 1550 has a 3&5/8 bore. how much larger in diameter would the plate have to be? I don't have the engine opened up yet, and don't know if the sleeves extend below the casting,or does the bottom plate have to be of a diam. to fit the primary clyder hole in the block?
Without looking at mine,I think you can go at least a half inch larger. The shirt on those sleeves hang below the block. Like I said,all you have to do with those wet sleeves is pop them loose and you can lift them out by hand. Lift them,probably 3/4 of an inch will be as far as you'll have to pull them.
