D-12 Hard Start
W M
Really hard to start, won't start unless I use the choke. Spark seems fine, runs fine, idles fine, just won't start normally.
When I try to start it, it turns over like the spark is too far advanced. I checked the timing, retarded it, but it made no difference.
When I use the choke it will start, but still turns over slow. Then it turns normally fast and will start.
Could this be stuck centrifugal advance? Seems like a carb problem would re-start without problem. This doesn't re-start either.
Thanks,
Wayne
Just to update my problem: I sprayed wd40 under distributor plate, waited an hour then tried it. Started fine. Several times. Went for a short ride (3 min or so) and it wouldn't start again. Could sound like an overheating coil but it started hard first thing this morning when it was cold. could the weights be getting stuck intermittently?
I'm not sure I'm reading you right. Is the tractor spinning over slowly or normally? In your 3rd sentence you said that it turns over slowly at first and then spins normally and will start. The starter should spin over at a good rate and constant. Your D-12 is an updraft carb and if it isn't clean and set right you will have to use the choke to crank it. Check your starter draw and make sure it is turning the tractor over properly.
