onetotaltoolman
Nearing the end of a D14 complete overhaul. Last to-do's are a leaking PTO lever O-ring, which predicated the removal of the tranny housing.
At first glance, the gears, to me, looked ok. However, after a close inspection, looks like I'm not so lucky. The engagement teeth of the infamous 3rd. gear on the pinion shaft are pretty torn up. AGCO parts book says to replace that gear and the reverse gear located next to it as a set. Crap - $450.00 for the pair. Let this be a lesson to those who think the A/C's have automatic transmissions. My question is this - I'm not a tranny guy. Once i start to pull the gears out for the replacements to go back in, is there anything else i should auto replace while the tranny is off of the machine. I've replaced about every seal on the tractor, so i'd just as soon do it that way and 50 years from now let someone else do the same thing again. Thanks for tips.
