D 17 Alternator conversation
4520BW
Dads old d17 is not charging again. ( genny is bad again. Tested using John T methods) would like to go to a delco 1 wire. Besides making a bracket what else would I need to change. I am guessing a different pertronix kit do to tractor going to neg ground. Thanks!
Yes to the Petronix swap. You will need a 3 Ohm coil or put a ballast resistor in front of the one you have if it isn't 3 Ohm. Pay close attention to the Petronix coil requirements. I would look for a Denso style alternator. They are cheap, like $120. They are a lot smaller and fit under the hood much better than a Delco. I use nothing but the Denso style on stuff. I really hate to see a hood hacked up to put a Delco alternator on a tractor. You have to watch out for the pulley size and style but they are easy to install.
OTJ
OTJ
Either will work, there is enough room on a D17 that sheet metal doesn't need to be hacked up to install a Delco type.
If you have 12 volt positive ground currently this might work.
$179.95D110SiSE12V63P63 Amp. Delco-Remy 10-SI type Self Exciting Internal Regulator Positive Ground Alternator
Wouldn't that have a 12 volt negative ground system already?
My understanding was all D-series were positive ground, and everything from the D15's up were all 12V. Which matches what Duner says above. If that's right, you don't need a new coil as you already have a 12V/3-ohm setup. But you will need a new Pertronix module since they can't be swapped between +'ve and -'ve ground (or go back to points/condenser. I like Pertronix kits for high-reving performance engines, but never saw the point of one in a tractor. I've had more Pertronix modules fail than points/condenser systems).
Of course, keep in mind all the other regular concerns going to a 1-wire Delco. The one-wires are self-exciting (unlike the 3-wire's) and have a minimum RPM they need to spin at to self-excite. While this isn't universally true, as a general rule the higher amperage the alternator, the higher the excitation RPM. If you get one that needs too high an RPM (or one with too large of a pulley) these old tractor engines may not turn fast enough to self excite. Generally, any of the 1-wire alternators 62 amps or less are fine for older/slower engines. I always go for the lower 35(ish) amp ones on tractors just to be safe, as they excite at really low RPM's. And 35 amps is still oodles of charging power for any old tractor.
Also, make sure it's grounded well. A lot of guys put on one-wires and have problems with them not charging. The alternator case needs to be grounded through where it bolts to the bracket, and then the bracket needs to be grounded well to the block. Dirty/rusty contact areas between alternator and bracket (or bracket and block) will result in it not charging. A lot of 1-wire 10SI's have separate posts on the alternator case for you to add an external ground wire to the block if you want.
