d fab trackmaster crawler backhoe
Not always, but in many cases new users have to have 5 or more posts on record before the site lets them post pictures (or links), due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there to get your post count up, trying to attach your pictures to each post. That may work after you make several posts. Then make your post here again. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is a total of 7mb per post (be it one picture or the total of several). Some pictures (often taken with phones), are too large and have to be reduced before they will post.
You need to start a new post of your own rather than tagging on to a 14 year old post. YT uses two different viewing formats, Classic and Modern. The people using Modern see the original post (and given the old date of the original posting some may ignore it), because Modern brings the thread to the top. Those viewing it in Classic will only see the post you made today as a single reply, none of the previous posts. So when seen in Classic, standing by itself, your post today doesn't mean much. You might get some info, it may get ignored, or some sarcastic comments because of that. And the fellows you are trying to communicate with, don't appear to be around anymore.
is anyone still working on one, im having weld on od sprockets made unless someone knows of weld repair ones from somthing else that will work
