#3 cylinder was dead, low compression as detected by putting thumb over plug hole. Push rod was bent and partially unseated from rocker. Exhaust valve was no longer stuck but when I put air on it there was some hissing from the muffler. I pulled the head and all looks OK. Thinking to just lap the exhaust and try again.
Also noticed some valves had seals, others did not. The #3 exhaust seal seems soft, unlike what expected (brittle, cracked, missing). Curiously, nobody sells valve seals for a D14. Should this engine even have valve seals?
