d15 Hydraulic leaking into trans?
Scoyt
My 1967 D15 Series 2 tractor, for some reason, leaks the hydraulic fluid I put in the hyd. tank into the transmission. I had to run a hose from the transmission to the filler tube on the hyd. tank. It seems to fill up the trans, then starts overflowing it out the top. Any ideas will be greatly appreciated!
No- the ram is inside the rear end. Need to take off the lift arms. Get the service manual, like I&T AC-17, it will have the details and views.
