D17 engine serial numbers correlation to year/series?
Does anyone have a list or info on allis d17 engine serial numbers
with correlation to year or series, specifically series 4.
I know the tractor serial numbers and engine serial numbers do not
match and I believe are pretty far apart on the few that I have sent
but any factory or personal documentation.
If your on classic look under research and info then serial numbers and you can find the year that way if you do the math so see where yours fits in
Thanks Richard
I did that and it only list the tractor serial numbers not the engine serial numbers. https://www.yesterdaystractors.com/cgi-bin/snlookup.cgi?mf=AC&md=D17
Seeing if they ever posted a engine number list like we have for the b c tractor models
Me neither I don’t think they ever matched but there is a way to correlate if the motor is period correct by casting number and the serial numbers being similar in comparison to other tractors of that year. Most of the 64-65 D17 series 4 have engine numbers in the 52-57000 thousand numbers and the tractor numbers are approximate 75000+ designating series 4
Just wanted more definitive info if anyone has any.
Any list for Allis engines matched to tractor years is just an extrapolation based on the assumption that X tractor has the original engine. If Allis ever did keep records, they are long gone and I'm not sure anyone saved them.
AaronSEIA
