D17 hydrolics don't work
I have a 1961 D17 and the hydrolics don"t work, I last used the tractor about a month ago and everything worked fine but I went to use it today and it does"nt even try to lift. Fluid level is fine, I took the main output line off the tractor and there is no pressure there so it must be inside but why all of a sudden would it quit like that? Ahy help would be great, thanks guys.
Since the fluid level is fine check the pin on the hydraulic lever linkage coupler down by the torque tube before you pull the pump.
Those plunger pumps pump all the time and are ran by a set of cam lobes, its hard to believe that a major malfunction occurred while setting.
I think you would still get a small amount of fluid even if the pressure relief valve was stuck open.
