I have a d17 series 4 that was converted to negative ground. While replacing the ground wire for the battery, I found a wire that was connected to the negative side of the tractor that was loose. I looked all over the tractor to find an open connection, and the only one I found was on the voltage reg. It's the L on the regulator, but it hasn't been touched since the tractor was restored. So, does anyone know if it should go somewhere or did go somewhere?
Behind that bolt is where it was. Did this originally go somewhere?
