I have a 1964 D17 series IV that is blowing fuses for the lights when it is running. Used a jumper in the fuse holder to run tests and without the engine running, lights work fine and I get a volt reading of 12.5. For a short time after tractor is started lights continue to work, then lights go out and dash light glows dim, still had volt reading of 12.5. After that the wire between fuse holder and key switch started to smoke. Shut tractor off and continued to have same problems. Let tractor sit for 20 minutes or so and rechecked, lights worked fine. Could this be a voltage regulator problem? Thanks for the help.
