Lketchem
Does anyone know what would make my
transmission puke tranny fluid out of
what seems to be a vent type bolt on
the TOP of the box forward left.
Only after pulling a drill or drag
Forward and to the left of the gear shift when sitting in the seat ?? Sounds like it's overfull on oil ?? Have you checked the oil level in that compartment ???? Drain out the excess oil thru the drain plug directly down from the foot clutch pedal, which takes an 1 1/8" wrench. If the hydraulic oil fill is located on the right side of the torque housing underneath the fuel tank, I would think it is getting LOW on oil and the dipstick you are concerned about is GAINING oil ?? Verify what is going on before I give you any advice.
