d188 thermostat
rray
My 67 504 would not warm up so I pulled the thermostat. It is not the standard automotive type. It has a butterfly valve and stuck in the open position. Is this type of thermostat required or will a standard automotive type work? What temperature is suggested, 180?
"It is not the standard automotive type."
Your thermostat is simply an older style, cars used 'em, too back then.
A new thermostat will be the style you are used to.
180? is the factory recommendation.
Thermostat from YT
