Anonymous-0
While using my D19 shredding, the hydraulic line that goes from the middle underside of tractor to the remote cylinder connection manifold beside the seat,started spraying fluid. I found a bad O ring on the coupling that is on the underside of the tractor just in front of traction booster. I replaced the O ring and stopped the leak. I had to disconnect both ends of the line to get enough movement to replace. I also changed the filter prior to filling with new oil. Now neither the remote cylinder nor the lift arms will work. Do I need to bleed air out of lines? If so how? Anything else I should check? Thanks
