You need to check all your bearings. Starting with the top and bottom shafts. They can't have any play. Don't need new bearings necessarily. I ripped 3rd gears teeth off. The problem it was just meshing about 1/2. When went back together new gears (from a donar trans) were the same. Needed new washers/shims. Can't just use the ones like the picture in the book. Tighten the ring and pinion , its bound to be loose. Tighten axle bearings. And bull pinion bearings. Plus all new seals. I put everything in the power director and it still slipped. So i took it out. Don't need anything but a short shaft from a donar and weld it to yours. When you take it apart you will understand. O I am pulling a D17 Diesel. No. Blower. 300 hp. Trans are the same to a D21. They have more teeth on trans gears so stronger. But they will fit in yours. But doubt you need them. If you are running 6-8 mph. I would start with a 426 engine. Sorry for rambling Vic. Call me. 618 599 8041Anybody pull an Allis Chalmer D19 and if so what did you do to make the rear end stronger.
I am gonna be running a d19 rear end not a 17.You need to check all your bearings. Starting with the top and bottom shafts. They can't have any play. Don't need new bearings necessarily. I ripped 3rd gears teeth off. The problem it was just meshing about 1/2. When went back together new gears (from a donar trans) were the same. Needed new washers/shims. Can't just use the ones like the picture in the book. Tighten the ring and pinion , its bound to be loose. Tighten axle bearings. And bull pinion bearings. Plus all new seals. I put everything in the power director and it still slipped. So i took it out. Don't need anything but a short shaft from a donar and weld it to yours. When you take it apart you will understand. O I am pulling a D17 Diesel. No. Blower. 300 hp. Trans are the same to a D21. They have more teeth on trans gears so stronger. But they will fit in yours. But doubt you need them. If you are running 6-8 mph. I would start with a 426 engine. Sorry for rambling Vic. Call me. 618 599 8041
Why. D17 stronger.I am gonna be running a d19 rear end not a 17.
So you believe a D19 Rear end is stronger than a 180 also. I don't really know, but I'm using final drives from a early WD. Because they are lighter. They haven't given any trouble yet. Knock on wood. I am worried more about the axle from the ring gear to the bull pinion gear. Because I've shorten them 10" and welded them together. But I stop at 5000lb. But can get down to 4000 lb. My main competition is a 460 IHC with a ,RD engine. But a 460 with a DT 466 engine. Stroked and poked to 800 plus cubes is another level. No turbo and 500 hp. Doubt it will ever stop."have to use weld-on hubs" ?? Well, that is probably true if the tractor has a bar type axle like a D-19 does. Should not be a problem using a D-17 rear end as there is no bar axle. Bar type axles using cast iron hubs are prone to breaking the hubs, so they (for safety) make you use a weld-on steel mount for the rear wheel. A complete misinterpretation of the rule. A D-17 rear axle is a flange axle which isn't a problem. By the way, a series 3 or 4 D-17 transmission is exactly the same as a D-19 transmission, just in a different housing. The final drives are much stronger on a D-19 than any age D-17.
