D20 Komatsu Dozer
RS16017
Looking at buying a little dozer. Found a D20 but there"s a problem where it will bind up while driving forward. Don"t know if it"s the drive clutches or something in the final drive. Anyone have one of these and had this happen. Thanks.
First guess would be bearing in the final drives, anything that binds up about a dozer can get costly quick. IF IT is a GEAR drive and not a power shift you can,t buy it cheap enough to like it.
I own a d-21, check sprocket for ware and track
pin and if any oil coming from clutch area - can be very costly to replaced seals and bearing in rear tract area - I think d-20 is stander transmission
which can cause problems that is very costly - other than that diesel usage is very good. been a good
machine to me - parts are very expensive
