Thanks for the fast response Old Magnet
! One of these days I will figure out how to operate this computer and thank folks for there time to reply.
Looking for a front idler, rails if they are better than what I have.
pads if better than mine. would you happen to have pictures of your machine? I may be interested in buying the whole thing?
I have a D6 9U. I don't get any fuel press from the transfer pump. I replaced the pump but still not pressure. When I opened the filter housing bleed valve and turned over the engine a lot of fuel came out. I checked the injector pump plungers and rack and freed the ones that were sticking. I bled out the air but it will not start. I does not seem to have a lot of pressure when I take the line off the injectors at the head. I have replaced the fuel filters and the gauge attached to the bottom of the fuel filter housing. The rack moves freely as it should. I have not measured the travel but will but I think it is correct. When I turn over the engine it does not even attempt to start. I'm really stumped so can use any suggestions.
