Dating an 841-D Powermaster
KenInGA
Hey y'all-
I've got an 841-D Powermaster, and as usual with the diesels, the serial number is loooong gone from battery acid corrosion.
Are there any other obvious dates or codes to look for on cast components, housings, etc that'll get me in the neighborhood? I know there's variability between the manufacturing dates of components versus the ultimate assembly of the tractor.
It was serviced by a dealer at some point to be upgraded to the late harmonic balancer, rotary oil pump, and the larger hood-mounted air cleaner. It's got a rebuilt-stamped injector pump on it, too.
This is more just for my pondering than anything significant.
Thanks!
Ken
Ken, this may help you a little, I'm sure others will know more -
Part number identifiers cast into 134 and 172 engine blocks (lower right side)
EAE 6015 - 134 1953-1957
EAF 6015 - 172 1953-1957
310905 - 134 1958-1959
310609 - 172 1958-1959
B9NN-6015C - 134 late 1959 early 1960
B9NN-6015A - 144D late 1959 early 1960
B9NN6015J - 172 late 1959 early 1960
B9NN6015B - 172D late 1959 early 1960
C0NN-6015G - 134 sleeveless late 1962-1964
C0NN-6015H - 144D late 1960-1964
C0NN-6015C - 172D-G late 1960-1964
C0NN-6015J - 172 late 1960-1964
As title sez "Dating an 841-D powermaster" Where did you pick her up at farmers only dot com? Seriously, Look on bottom section of block right side for casting numbers and left
side production date code numbers.
