David Brown 1210 adding hydraulic remote
BrianCarlin
I have a 1977 David Brown 1210 with a single set of hydraulic remotes. I just purchased a International 535 Moldboard plow that has a sidehill hitch and I would like to add another set of remotes. Is there an aftermarket value body that would stack on top of the original remote?
no aftermarket that I know of but if you find one on a salvage yard all it tales is longer bolts and you can stack as many as you need on
cnt
I have used one of the flow divider valves that lets you run two cylinders with one remote. Not a bad solution if you are only operating one of the cylinders occasionally. It is a little clumsy if you want to switch between cylinders frequently. A relatively inexpensive option.
