David Brown 1210 with Case loader question
BrianCarlin
Is there an easy way to remove and reattach this loader? I just picked it up and the tractor needs degreasing and oil leaks fixed. It would be much easier with the loader off.
Nope, that is not a quick detach loader. You will need to remove the boom and cylinder pins from the sub frame, prop the boom and bucket up somehow, and uncouple what ever hose conections that the tractor has.
Looks like a pretty straight tractor.
Loren
As Loren said, but there should be to mounting points to put legs under the main frame just ahead of the lift cylinder. I have the same loader on one of my tractors and have a set of the original stands. Do not know how they get separated from the loader and tractor.
I'm lucky to have a nice grille. It hasn't been plowed under yet... Mine does have a scarred nose though.
Should be on the right hand side of the engine. Use a crescent wrench to take plug out. Round canister just ahead of the lift pump.
DB4600, I have the grilles for my 885,990's and one for a 1200 series. I try to pick them up whenever I run across them. If I buy a tractor that doesn't have one I will ask and they usually have it hanging on the wall along with the original top link.
