david brown 885 dies
I have a david brown 885 diesel .Started for the first time this year and it ran for about seven minutes and it died and it wont start again.>So I changed the fuel filters ,bled the lines and it fired up right a way ,it ran for about 10 minutes and died again and it wont start What could be the problem ?
The intake tube inside your fuel tank is plugged with a leaf or rust particles. Blow it out in the reverse direction with compressed air. You may have to vacuum out the fuel tank to get the crud off the bottom. There is also a metal screen inside of a glass bowl on top of the fuel pump which may need attention. Try those and report back.
