David Brown 885 diesel throttle problems.
rfvaca
Hi, I have a DB 885 Diesel. The throttle control and throttle cable function perfectly moving the throttle lever on the injection pump through it's full range of motion but it does not change the engine speed at all. The engine runs at about a fast idle only. The lever moves but engine speed never changes. Does anybody know what would cause this? Thanks
My 885 has the opposite problem to yours. The throttle cable and lever work fine but the kill lever cable doesn't, although I can shut it off by
manually moving the lever up. If your throttle lever is unresponsive, it can only mean that the external lever is disconnected internally. Be sure the
little screw on top is tight. If it is already, you'll have to get inside of it to see where the disconnect is. My 885 is the toughest, most
dependable bushogging tractor I ever owned.
Trouble is inside the injection pump, I had a Perkins pump act like that last week. Works fine now after I tore it down, then repaired and reset the calibration.
(quoted from post at 04:19:33 06/02/20) Trouble is inside the injection pump, I had a Perkins pump act like that last week. Works fine now after I tore it down, then repaired and reset the calibration.
Thanks very much to both of you for your responses.
So what happened inside the pump that had to be repaired. I understand the calibration would need reset but aside from that, how difficult is the repair you're referring to? Thanks
Pump governor weights, shaft sleeve, arm linkage wear, or severely gummed up with bio diesel are common causes. Test bench is the only way to make sure governor is working correctly after repair..
It's a machine to drive injection pumps for flow testing, governor action, advance curve, etc. High pressure injection pumps have three main jobs, pressurize fuel, time fuel, and meter fuel..
