Just picked up a Davis 210 backhoe on a Minneapolis Moline 335. Since most Davis equipment appears to be associated with Massey tractors, Im posting here with questions. This has the Davis 102 loader frame on it, presumably for some counterweight and the hydraulic reservoir. It appears to have never had a loader on it. Is filling the reservoir up to the two small plugs far enough to operate the backhoe, or should it take more fluid than that?
What hydraulic fluids do you use in these? The loader manufacturer calls for Type A ATF. Im running some TSC brand 46 hydraulic fluid in it to get the water worked out of the system. It will only be used in warm weather, and a little extra viscosity might help a couple of the leaks.
The roughly 200 pound counterweight on the front loader frame plus another 500+ pounds stacked on top of that at least keeps the front end on the ground.
