Davis Loader Monstrosity
Wolfram
This thing is big! Too big! I have to get it off of the TO-30 and sell it. It's just too heavy to keep on the tractor with all the grass cutting that we will be using it for.
Question - does anyone know what size hydraulic line plugs I need for the hoses? I need to plug the lines when I remove it from the tractor.
I'm not sure what you have or how it's plumbed in, but if it's an open center system with a single pressure line FROM the tractor to the loader and a return line back to the tractor, you will have to connect the two lines together when the loader is removed, NOT cap them off.
UNLESS it's closed center or has a valve on the tractor to switch the "power beyond" function off.
It's a Model 100 loader. It goes up and down. The bucket tips. It can't really "dig" into the ground by hydraulic pressure. It's simple. Just on and off, really. Looks like I have to connect the lines.
do you have a hydralic pump on front of the tractor??, if so then the other comment applies
one side of the loader is likely the oil resevoir, could remove front pump along with the loader and be done with it
if you are using internal tractor hydralic pump thats a different story
Going back to your comments, I suppose I don't understand what you are telling me. The Davis loader has its own hydraulic reservoir and pump. It doesn't use the tractor hydraulics in any way.
So do I plug the lines? If so, does anyone know what size plug?
