Davis Loader pump
Working on my TO35 with Davis 200 loader. The front hydraulic pump drive shaft has been welded into the drive pulley that bolts to the front crankshaft drive. Weld job was not centered. The shaft outer end wobbles 3/4 of an inch out of center. Have been looking for replacement pulley and shaft, plus special bolts with rubber bushings that mount to hydraulic pump. Not having much luck. Any suggestions of where I might go to find parts.
Our Puckett grader used a Dodge coupler for the crank driven pump. Can you cut the weld on the pulley and re use it. A coupler would eliminate the need for bolt rubbers
look on this site in parts for TO 35, hydraulics section, bottom of the page I believe what you are looking for is a #192169
If you also need the shaft and adapter plate I believe they are in the ford parts pages. I also had to replace the front pulley and plate on a to35.
Thank You for all replies. Son (a very good machinist) liked the coupler idea. He is using his lathe to cut out old shaft from tractor pulley, attaching a coupler, cutting shaft to length and machining in a 3/16 key way to outer end to permit pump attaching. So should solve problem.
