Davis loader
I've got a Davis 102E loader on an International 300U. I believe I can add hydraulic fluid thru the vent on top, but I haven't noticed where to check the hydraulic fluid on this unit. I'm sure someone out there knows. Thanks
Typically, the Davis loaders have a small (1/8") pipe plug in the loader frame/tank a few inches down from where the fill port is.
You remove the plug and add oil 'til oil starts to come out of the test port.
On the newer models on our MFs, the level is indicated by a dipstick hanging from the vent cap. I think it’s about 17” below the vent/filler base. Seems it’s might be about where that small dia hose comes out the back of your tank.
The only plug is the one at the bottom that you can see in the picture.
I'm thinking maybe unhook that small hose, fill from the top until it reaches
that level, but I'm open to suggestions. Thanks
