Day in the barn
grandpa Love
Spent most of Saturday in the barn.
Moved sickle mower frame over so drive
shaft was straight. Then greased it up
good. Found a zerk on one u joint that
was broken off. Looks like it never got
grease. Fixed that. Also , after close
inspection we saw that the inner part of
drive shaft was bottoming out. So we
trimmed it a couple inches. Then
tightened up a couple sections and
adjusted the wear plates. Cut my lawn
for 15 minutes and only got one clunk
sound, that was when i locked up one back
tire and whipped around hard. Maybe
that's fixed. Then we put a starter on
the "new" cub. And new metal gas line on
the 951. Fuel cutoff under gas tank was
leaking so rebuilt it. Also got new water
pump on. Got fan and alternator back on.
Now the float is sticking!! Grrrrr.
Morning, bet it was a little warm doing that yesterday. Got to put some new sections on my mower and clean up some ditch banks here. Thinking I will wait a few more days. By the way, did u make contact about the project table?
Often, when you fool with the fuel lines, a little piece of something will break loose and wedge between the needle and seat. Shut off the fuel, drain the carb so the float drops all the way down, and turn the fuel back on till it gushes out the drain. Sometimes this will flush the dirt through the needle and you won't have to take it apart. Good luck, Lazy Chip
