DB 780 Throttle Stop Spring
I purchased a DB 780 with a few minor issues I'm trying to correct. One problem is the throttle stop button and throttle stop spring configuration. The stop spring was setup like image 1 when I got it. It seems like it should be setup like image 2, but if I set it up that
way it is impossible to turn off the tractor without pushing the lever up by hand. I have tried running it like image 3, but after about 30 seconds it slowly shuts off as the spring contracts. Any ideas on how these springs are supposed to configured?
A>> they're the wrong springs..
All they are is "assist" springs, you really don't need any of them..
IF you don't have any problem w/ the shut off lever vibrating to the shut off position, take them off..
pic 2 is pretty close, but there shouldn't be any/or that much tension on the spring in the run position on the shut off.
You could run a smaller spring to the linkage ball on the shut-off to the hole on the throttle..
OR just remove them..
I thought the same thing, but the tractor came with an old rusted spring in the configuration seen, so I ordered the new springs from Case off the parts schematic so I figured they were correct. I'll just take them off and get an new throttle stop cable and housing.
I know this is an old thread, but in image two, isn't the shutoff a pull of the stop cable? It seems that the spring configuration in picture two will keep the tractor in a perpetually off position.
I'm trying to understand how to hook up my cable, and I'm struggling with the same issue.
