The Claw
Is there a speedy sleeve for a 1953 DC for the shaft that the brake discs go on (differential carriage)? Have some grooves worn in it.
u would have to measure the shafts then inquire about the sleeves. nothing would be specific to that tractor. plus if its not much of a groove just replace the seals. a new seal will work and that is a slow turning shaft also.
I am almost sure the new sleeves are narrower, and you can use two on the install. The second sleeve should land in an area not affected by corrosion or pitting.CM
<video width=90% src=https://www.yesterdaystractors.com/cvvideos/cvvideo109624.mov controls>http://
The third pic is not a DC carrier,but for demonstration purposes. Notice that I installed Two seals. Best of luck in your project .CM
(quoted from post at 10:13:24 12/01/21) I am almost sure the new sleeves are narrower, and you can use two on the install. The second sleeve should land in an area not affected by corrosion or pitting.CM
&lt;video width=90% src=https://www.yesterdaystractors.com/cvvideos/cvvideo109624.mov controls&gt;http://
&lt;img src=https://www.yesterdaystractors.com/cvphotos/cvphoto109626.jpg&gt;
&lt;img src=https://www.yesterdaystractors.com/cvphotos/cvphoto109628.jpg&gt; The third pic is not a DC carrier,but for demonstration purposes. Notice that I installed Two seals. Best of luck in your project .CM
This is not a DC carrier, but you see that I was able to install two seals,as I believe you will be able to.The newer seals are not as wide as the OEM seals
