DC trans fluid
clee
I have a Case DC with power lift in rear. (3 point). A hose to the lift cylinder broke last fall. Now I am ready to get it going. Can someone tell me what type of fluid to use and approx. where the fill cap is. I bought a manuel from YT, but the pictures are so dark I cannot make out where the arrows point. Also any advice on how to flush the old fluid out. It looked like chocolate milk. Thanks.
Fill should be a pipe threaded plug on top of the trans. under the seat, think its 3/4inch. There is a smaller plug about 1/2 way up the rear housing that you remove and use to witness the fill level. Guess you could put some kerosene in and swish it around a while to clean some sediment out. Thanks for posting I was running my DC a few hrs today wondering what I could service next - you found it.
I used diesel fuel,and drove it around.Then put new #90 weight in my "DC",and she had a big smile.
Remember thou,your hydraulics are seperate,and take hyd fluid in there.You should see that plug right above pto and hyd.And there is a little check plug about half way up
