(quoted from post at 16:06:29 11/27/23) Also, make sure you have the plug wire
order correct. Someone else on here will
tell you for sure, but I'm pretty sure
the 600 and 800 series firing order is 1-
2-4-3, unlike the much more common 1-3-4-
2.
It's common to find tractors with the 1-
2-4-3 firing order with the 2 and 3 leads
swapped by someone who didn't realize
this: I've bought a couple of Fordsons
cheap because the PO did that and
couldn't figure out what was wrong.
They'll still (surprisingly) run like
that, but very poorly. I think the rotor
turns CCW in that dizzy (I could be
misremembering - crank with the cap off
to check). If I'm right, the leads should
go 1-2-4-3 in counter-clockwise order.
(quoted from post at 17:50:18 11/27/23) what do u mean by dead cylinder? you have compression and spark u say.
I'll give it a try, Thanks!(quoted from post at 19:00:06 11/27/23) Hello sm welcome to YT! I am will add a second to
Skippers post on the vacuum leak. Spray starting fluid,
carb cleaner or direct an unlit propane torch toward
the mating area of the manifold and head. A change in
the engine sound would signify a vacuum leak. Of
course not discounting what the others are suggesting
either.
