Dear barney
SVcummins
as far as overloaded wagons go, i think i will add borax to the list. these wagons were not just used once in a while, but huge wagons used for years, two wagons and a water tank totalling over 73,000 lbs covering 165 miles in 10 days. the two wagons weighed 7,800 empty, each.
and a engels coach shop in joliet montana recently recreated the pair of wagons and the water tank, great videos to watch on youtube about the construction, wheels weighed over 1,000 lbs each
And yup they had brakes on those wagons too. Albeit they may not have been the best brakes. Though in the sand I doubt they would be needed as much as the flotation those big tall wide wheels were needed in the sand with the loads they carried. Is a bit surprising they could pull that load with just 20 teams of mules over the terrain they would have had to traverse.
That was for the Borax wagons out of Death Valley. If you have a roach problem, get a box, usually used to sweeten laundry....I put it
down on the floor prior to putting vinyl or carpet when I built the house. Been in this house 42+ years and counting and I bet I
haven't seen a dozen roaches....which probably came in on a container from some kind of supplier...
