Dear barney
SVcummins
There is 12 volts At your starter there is no magic connection that takes it away
Sorry, but not always. One needs to find out what is being worked on. How many Fords (for one) that used a remote solenoid mounted on the fender well, or elsewhere, only had power to the starter when the solenoid was engaged? Many thousands of them.
I think the point is at the end of the battery cable whether it connects to the remote solenoid like the ford solenoid or the solenoid mounted on the starter like most other starters have it will still be the 12 volts on a 12 volt system nothing to magically change that unless there is a weak battery or a poor connection along the line.
(quoted from post at 07:25:52 01/10/22) I think the point is at the end of the battery cable whether it connects to the remote solenoid like the ford solenoid or the solenoid mounted on the starter like most other starters have it will still be the 12 volts on a 12 volt system nothing to magically change that unless there is a weak battery or a poor connection along the line.
I agree with your statement (and understand where SV is coming from), even though it may appear I don't, based on what is seen in this one post. However, the rest of the story behind this post is here.
https://forums.yesterdaystractors.c...&postdays=0&postorder=asc&start=0
Thus forms the interesting activity of diagnosing starter issues on a JD 3020 diesel. You get 12 volts every where you test in the starting circuit. By the way that's the best fuel filter mountings design JD used.
