Dear barney
SVcummins
Had to torch the inner bearing off had to pull the tire and hub brake drum off with a 5 ton chain puller
https://www.yesterdaystractors.com/cvphotos/cvphoto117074.jpg
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto117075.jpg
Had to do that to a dodge pickup on the side of the road one time very slightly nicked the spindle with the torch. Boss complained. I said it could still be on there and we could set here forever. I polished it with some emery cloth put a new bearing on and away we went. Was still on there last time I saw it. It had started to weld it's self on to the spindle turning.
Polish it up some and locktite on the spindle to help the bearing if it is just slightly loose and a puncture wound punch, all will be good.
Been there done that, good job. I had a friend who thought I used the blue wrench a little excessively. This is after I helped him replace the u-joints in his CV joint. I should have let him remove those glued in joints without heat.
I think they got the parts today might head out in a bit see if I need to put it back together. Yes Ive had to knurl a shaft with the puncture wound punch before to get a bearing to fit tight on the shaft
