Dearborn PTO shaft
I'm working on a dearborn 14-59 sicklebar mower and need the universal joints for the PTO shaft. I can't seem to find them locally or from the internet. Does anyone around here have a part number for them or has found them somewhere please let me know. It has a 7/8" diameter bearing cap and is 2 1/2" from end to end and uses clips on the outside of the bearing. Thanks for any info that can be provided.
(quoted from post at 11:02:35 11/25/14) I'm working on a dearborn 14-59 sicklebar mower and need the universal joints for the PTO shaft. I can't seem to find them locally or from the internet. Does anyone around here have a part number for them or has found them somewhere please let me know. It has a 7/8" diameter bearing cap and is 2 1/2" from end to end and uses clips on the outside of the bearing. Thanks for any info that can be provided.
My local CNH dealer:
SPIDER
Product No: 29537
$34.93
TOH
Thanks for the info fellas. TOH, I called Antietam tractor and the guy said he couldn't help me, I guess he just didn't want to. Do I dare go to ceresville? I've had more problems with those knuckleheads than enough. I guess now that I armed with a part number I can call back and get a real answer. Thanks again for the very fast replies. Machine
(quoted from post at 11:57:22 11/25/14) Thanks for the info fellas. TOH, I called Antietam tractor and the guy said he couldn't help me, I guess he just didn't want to. Do I dare go to ceresville? I've had more problems with those knuckleheads than enough. I guess now that I armed with a part number I can call back and get a real answer. Thanks again for the very fast replies. Machine
Ceresville was the dealer I originally gave to the CNH parts lookup site. Did you call before or after I posted the part number? If before I would call back with the part number and talk to someone with an interest in being helpful. Gaithersburg Equipment says "in stock at warehouse - please allow 1-3 days for delivery to dealer". If it was me I'd save my gas money and order online with G'burg - $1.25 cheaper than Ceresville and only a couple miles further ;-)
CNH parts store online
TOH
It's a Rockwell L10S series joint.
Knowing that, you can get a cross kit from MANY industrial or even auto parts sources.
The Precision U Joint part number is 870.
MANY auto parts stores carry that brand or can cross it to the brand they carry.
Thanks for all the good info, I knew I could count on you guys! TOH, I hope you have your chains and plow on, if you need a hand this week give me a holler. I called antietam tractor before you gave me the part number and was told it wasn't made anymore. I called back after you posted with the number and talked to the same guy, he applogized because he looked up the wrong part (That's why I usually like to go in to the store so I can look at the diagram myself, partly my fault I guess) but he's ordering them for me. At least I have until spring time to get it going. Thanks again to everyone!
(quoted from post at 20:00:13 11/25/14) Thanks for all the good info, I knew I could count on you guys! TOH, I hope you have your chains and plow on, if you need a hand this week give me a holler. I called antietam tractor before you gave me the part number and was told it wasn't made anymore. I called back after you posted with the number and talked to the same guy, he applogized because he looked up the wrong part (That's why I usually like to go in to the store so I can look at the diagram myself, partly my fault I guess) but he's ordering them for me. At least I have until spring time to get it going. Thanks again to everyone!
I am going on the theory that the weather man is never right. BUT I did do the Turkey day grocery shopping today - just in case ;-)
You should also double check that part number by looking at the diagram I linnked. I just realized they show two different u-joint assemblies and I am not sure which one you need.
TOH
