Bob Purinton
I found a front facing blade today that can be used for moving dirt or snow. (I guess)
The blade is about 5 foot wide and has a pull pin to turn the angle of the blade just behind it where it fastens to the frame assembly. Also in this area is a data plate that says Dearborn something or other. It's kind of an oval shape.
The frame assembly goes under the full length of the tractor and uses the lift arms to raise and lower the blade by means of cables that run up each side and attach to the tractor somewhere after passing through a pulley on each side of the frame. The frame looks like a piece of 3 inch tubing bent double with the blade brackets mounted to the bend of the tube and both open ends of this tube at the rear of the tractor with something that looks like a pair of bicycle handlebars inverted between them. CRS may be creeping upon me now but I think I got the form right if not the function.
There are alignment "Pads" that mount to the front axle to prevent the frame moving from side to side and other brackets that mount under the rear fenders to provide a place to lock chains on either side for moving the tractor without using the hydraulics to hold the blade up off the ground. Also, in these brackets are notches where pins fit in.
Does anybody care to hazzard a guess as to what I've found and is it worth the $600 the owner wants for it. Can replacement parts be found for this?
Everything is there except for one of the brackets that goes under the rear fender. the owner said he would take the remaining one and have a machine shop make a mirror image of it to go on the other side. Both cables will have to be replaced as the are frayed and unusable. Will these have to be bought somewhere or can they be made up?
Thanks for any help.
