Deere 245 dies
TomW
I have a Deere 245 with a 14 hp engine that will run fine until it heats up. When the mower is on and it is hot it sputters and dies. If I shutdown the mower the engine runs smooth. It was giving me fits just running earlier this year. Thus far it has new fuel lines, filter, pump, plug, spark control, head gasket, fuel shutoff and had the valves checked. Replacing the fuel pump made the most difference in running but it still doesn"t like to cut grass. Any suggestions on where to go. Can I test the mower clutch to see if it is shorting my spark? Thanks
Check for dirt/water in carb bowl,main jet & internal passages of carb,if carb has a hi-speed needle,try opening 1/2 -3/4 turn,may be set too lean,check mower deck bearings,same may be bad/going bad,causeing eng overload/overheat or generating enough vibration on tractor frame to affect safety sw's or wiring connections at sw's,check that blades are balanced.Most eng but not all use a ground kill for ign,,the seat sw is usually the start of safety circuit,1 side being grounded to chassis or battery neg,other side of sw feeds rest of safety sw's(clutch/brake,pto sw)if seat sw going bad/loose in mount vibration from mower may cause sw contacts to close,completeing grounding circuit,killing eng ign.Try this locate ign kill lead at eng & disconnect,run tractor as you normally would,if cutout problem goes away,problem in safety sw's or elect system,if you still have cutout with wire disconnected,problem in fuel system or possibly in on eng wiring/ign system,you'll have to reconnect wire to stop eng as all safety sw's & ign sw are bypassed with wire disconnected,eng free running.
