Deere 467 baler
tomstractorsandtoys
Baled my first 8 bales tonight with my new 467 baler. Took awhile to figure the bale monitor out and get the net wrap going. Sure makes a nice bale. Old baler was 4x4. I am making 4x5's now. Sure is a good bit more hay per bale. I want to mess with the variable core feature some tomorrow as these bales are super tight. I think the bale kicker might be coming off as I have already put one bale where I did not want it and I am not even on the hilly fields yet. LOL Maybe wife can get some pics. Next project is the AC in the 4230 as it has a leak. Adding a can a day right now but only have one more day of baling and 2 more of chopping untill it gets a break. Tom
Tom
I can visualize how push-bar could create problems on hilly fields.
You can ""disable the bale push-bar(kicker)"" by disconnecting the chains on each side & placing loose chain ends on hook on each side. In addition to lowering core pressure you could also lower bale forming hyd pressure. JD X67 & newer models seem to be very good & reliable rd hay balers. My 2nd 467 is approaching 60,000 combined bales using two 467's.
Tom
What is a push bar? I am thinking of fabricating a kind of spring loaded ramp for my old Hesston baler to let the bale out on so it will let the bale roll away a bit from the baler. It annoys me that I have to back up a little before unloading a bale. Otherwise the dropped bale is in the way when letting the tailgate down. Is such a simple ramp what you call a push bar?
Push-bar moves rearward & pushes rd bale when rd baler tailgate is opened. JD offered bale ramp on smaller rd balers. I've never operated a baler with bale ramps. But I think I would prefer bale ramp over JD rd baler push-bar. I once accidently put a rd bale in stock pond when I had rear of baler aimed in incorrect direction.
