Deere 6600 injection pump
cooop
I recently bought a John Deere 6600 for scrap price and I am trying to get it to run. The combine has a rotary screen 329 diesel in it. It turned out that the combine itself is in better shape than I thought it was and I am trying to get it fixed. It had sat with biodiesel in the pump and it is gummed up. I freed up the metering valve because it was stuck and then I got it to start and run for a few seconds then it cuts out and dies. Every time, It will start and run for a few seconds then die like it is short on fuel. The injection pump has a good flow to it. Does anyone have any idea what could be wrong with this combine? I am trying to keep this as low cost as possible so, rebuilding the injection pump is out of the picture. However, a friend of mine parted out a 6600 Deere some 25 years ago with a 329 diesel and he will give me the injection pump for free. So if I can't somehow remedy the pump on the combine now, I could put this pump on it, if someone gave me the timing information. This pump has never seen biodiesel and was properly flushed out after removal, so I know this pump would work. Any suggestions on how to possibly fix the pump on the combine without spending too much on it? Is anybody willing to scan and email me the pump timing info out of a manual? Thanks, and sorry for such a long post.
neighbors 4435 died a few years back picking corn, cleaned lines,strainers replaced filters had a good flow of fuel to the pump it would run 5 to 10 minutes die again, after several times air bleeding pump, i was double checking everything and noticed a glass ball inside the fitting that the return line is connected to on the pump, thought maybe it was sticking shut so i used a small punch to crush it then remove it, solved the problem so far,asked a mechanic i know about it he said he had done that several times but eventually would have to replace the pump
It might be worth your time googling "how clean out biodiesel". There may be chemicals specifically designed to do that because I'm sure theres lots of hippies that have clogged their VW's on this stuff before.
Have you replaced the fuel filter? if not, do so.
The glass bowl under the fuel tank, there is a round screen on top, same size as glass bowl. If that screen is still in there, take it out and throw it as far as you can. I ran soydiesel in my 6600 one year, went through a lot of filters till the tank got cleaned up.
